# LimUtil --update scrogged - how to start over?
**URL:** <https://discourse.myriadrf.org/t/limutil-update-scrogged-how-to-start-over/689>\
**Created:** [6 February 2017 20:50 UTC](https://discourse.myriadrf.org/t/limutil-update-scrogged-how-to-start-over/689 "2017-02-06T20:50:07Z")\
**Showing post:** 3
**Author:** ![Zack](https://yyz2.discourse-cdn.com/flex034/user_avatar/discourse.myriadrf.org/zack/32/89_2.png) [@Zack](https://discourse.myriadrf.org/u/Zack)\
**Post date:** [7 February 2017 09:06 UTC](https://discourse.myriadrf.org/t/limutil-update-scrogged-how-to-start-over/689/3 "2017-02-07T09:06:18Z")
hi @cswiger,
It looks like there was firmware update interrupt. Now FX3 MCU boots into bootloader mode.
You may try the following steps using LimeSuiteGUI:
1. Download the latest firmware [image file](https://github.com/myriadrf/LimeSDR-USB_FX3/blob/master/Debug/LimeSDR-USB_fx3_fw.img);
2. Connect the LimeSDR board;
3. Run LimeSuiteGUI and connect to the device;
4. Go to Modules -\> Programming menu;
5. Select FX3 in Device list and Firmware to RAM in Programming mode. Open image file you downloaded in the step 1;
6. Push Program and wait till programming is finished;
7. Connect to the device again in LimeSuiteGUI. Now you will see it as usually;
8. Perform step 4;
9. Set everything as in step 5 just choose Firmware to Flash instead of Firmware to RAM in Programming mode;
10. Push Program and wait till programming is finished.
Check if everything is OK by re-connecting the board.
_[View the full topic](https://discourse.myriadrf.org/t/limutil-update-scrogged-how-to-start-over/689)._
