# LimeSDR Mini v2.4 Rx only works when you transmit something
**URL:** <https://discourse.myriadrf.org/t/limesdr-mini-v2-4-rx-only-works-when-you-transmit-something/8521>\
**Created:** [7 October 2024 09:26 UTC](https://discourse.myriadrf.org/t/limesdr-mini-v2-4-rx-only-works-when-you-transmit-something/8521 "2024-10-07T09:26:27Z")\
**Showing post:** 2
**Author:** ![sergey](https://yyz2.discourse-cdn.com/flex034/user_avatar/discourse.myriadrf.org/sergey/32/4871_2.png) [@sergey](https://discourse.myriadrf.org/u/sergey)\
**Post date:** [7 October 2024 21:03 UTC](https://discourse.myriadrf.org/t/limesdr-mini-v2-4-rx-only-works-when-you-transmit-something/8521/2 "2024-10-07T21:03:55Z")
This reminds me a similar issue I was having with my Mini v2.2: [LimeSDR Mini V2 reading samples from RX FIFO - #2 by Zack](https://discourse.myriadrf.org/t/limesdr-mini-v2-reading-samples-from-rx-fifo/7900/2)
Not sure there is something you can do from just user side of gnuradio, I am not a huge expert of it. Maybe there is a way to configure TX channel without starting a stream.
Perhaps gnuradio can adopt some sort of quick fix, similar to the examples in the LimeSuite: [Fix singleRX example to work correctly with LimeSDR Mini V2 · myriadrf/LimeSuite@e353507 · GitHub](https://github.com/myriadrf/LimeSuite/commit/e353507decc7d4c525421c539fb7dbc47ab207cc) (at least until LimeSuiteNG is stable as it provides much cleaner API for developers, and also supports new XTRX hardware).
_[View the full topic](https://discourse.myriadrf.org/t/limesdr-mini-v2-4-rx-only-works-when-you-transmit-something/8521)._
