I suspect I have “holes” in the recorded data.
So I wrote:
config.channel[0].rx.testSignal = true;
Before running:
device->Configure
What wave shape should I get ?
Does this shape depends on parameters like: sample rate, gain, bandwidth etc. ?
I followed the sample code basicRX. The while loop contains:
int SamplesRead = stream->StreamRx(pDst, Rest, &rxMeta);
But there is no use in rxMeta. Should I use it somehow to make sure there are no holes in my recording ?
Thank you very much,
Zvi
