Thank for the datapoint - Earlier versions of the ExtIO_LimeSDR.DLL didn’t support the Mini because even I tried to see if it would function and it didn’t. Good to know that this 'Tv2 version is supported on both flavors of Lime now.
Yes! I found how to solve the problem!
Some tricks with Windows registry, and it works
I don’t know will it work in other versions of Windows, but on W7x64 it works fine!
So, steps to do:
Open Registry editor and make search of string “HDSDR”. You will get some results, but you need something like [HKEY_USERS\S-1-5-21-594861094-2120942956-3325901376-1001\Software\HDSDR]
This long number between HKEY_USERS\ and \Software should differ from mine. You have to copy-paste this YOUR numbers to notepad.
Now create empty text file, and copy this text into it:
@Armin
While this is nice workaround it doesn’t solve the problem that it doesn’t work below 30MHz.
Can you set SXR to 30MHz in LimeSuite and tell me what happens? It’s near Calculate button at SXR tab.
And if possible do it again after HDSDR fails to set it below 30MHz, connect the Mini board to LimeSuite and don’t press Default button.
