Xubuntu 17.04 64-bit, installed yesterday with a “sudo apt-get update && upgrade” run immediately before running the steps you have listed in the initial post.
If I need to downgrade to 16.XX, no big deal.
Thanks again!
ETA: More verbose log data – “Package soapysdr is not installable.” seems like a clue. To what, I don’t know.
jason@jason-N56VM:~$ pybombs install soapysdr
PyBOMBS - INFO - PyBOMBS Version 2.3.2
PyBOMBS.install_manager - INFO - Phase 1: Creating install tree and installing binary packages:
PyBOMBS.install_manager - ERROR - Package has no install method: soapysdr
jason@jason-N56VM:~$ pybombs -vv install soapysdr
PyBOMBS.ConfigManager - DEBUG - Reading config info from file: /etc/pybombs/config.yml
PyBOMBS.ConfigManager - DEBUG - New config items: {}
PyBOMBS.ConfigManager - DEBUG - Reading config info from file: /home/jason/.pybombs/config.yml
PyBOMBS.ConfigManager - DEBUG - Template directory: /usr/local/lib/python2.7/dist-packages/pybombs/templates
PyBOMBS.ConfigManager.PrefixInfo - DEBUG - Inspecting config file: /etc/pybombs/config.yml
PyBOMBS.ConfigManager.PrefixInfo - DEBUG - Inspecting config file: /home/jason/.pybombs/config.yml
PyBOMBS.ConfigManager.PrefixInfo - DEBUG - Cannot establish a prefix directory. This may cause issues down the line.
PyBOMBS.ConfigManager - DEBUG - Full list of recipe locations: [‘/home/jason/.pybombs/recipes/gr-recipes’, ‘/usr/local/lib/python2.7/dist-packages/pybombs/recipes’]
PyBOMBS.ConfigManager - DEBUG - Named recipe locations: {‘gr-recipes’: ‘git+https://github.com/gnuradio/gr-recipes.git’}
PyBOMBS.RecipeListManager - DEBUG - Adding recipe location: /home/jason/.pybombs/recipes/gr-recipes
PyBOMBS.RecipeListManager - DEBUG - Scanning directory ‘/home/jason/.pybombs/recipes/gr-recipes’ for recipes…
PyBOMBS.RecipeListManager - DEBUG - Found 172 new recipes.
PyBOMBS.RecipeListManager - DEBUG - Loading templates.
PyBOMBS.RecipeListManager - OBNOXIOUS - Adding template /usr/local/lib/python2.7/dist-packages/pybombs/templates/boostflags.lwt
PyBOMBS.RecipeListManager - OBNOXIOUS - Adding template /usr/local/lib/python2.7/dist-packages/pybombs/templates/empty.lwt
PyBOMBS.RecipeListManager - OBNOXIOUS - Adding template /usr/local/lib/python2.7/dist-packages/pybombs/templates/prefix.lwt
PyBOMBS.RecipeListManager - OBNOXIOUS - Adding template /usr/local/lib/python2.7/dist-packages/pybombs/templates/setuptools.lwt
PyBOMBS.RecipeListManager - OBNOXIOUS - Adding template /usr/local/lib/python2.7/dist-packages/pybombs/templates/sdk.lwt
PyBOMBS.RecipeListManager - OBNOXIOUS - Adding template /usr/local/lib/python2.7/dist-packages/pybombs/templates/distutils.lwt
PyBOMBS.RecipeListManager - OBNOXIOUS - Adding template /usr/local/lib/python2.7/dist-packages/pybombs/templates/bjam.lwt
PyBOMBS.RecipeListManager - OBNOXIOUS - Adding template /usr/local/lib/python2.7/dist-packages/pybombs/templates/cmake.lwt
PyBOMBS.RecipeListManager - OBNOXIOUS - Adding template /usr/local/lib/python2.7/dist-packages/pybombs/templates/autoconf.lwt
PyBOMBS.RecipeListManager - OBNOXIOUS - Adding template /usr/local/lib/python2.7/dist-packages/pybombs/templates/bootstrapautoconf.lwt
PyBOMBS.RecipeListManager - DEBUG - Adding recipe location: /usr/local/lib/python2.7/dist-packages/pybombs/recipes
PyBOMBS.RecipeListManager - DEBUG - Scanning directory ‘/usr/local/lib/python2.7/dist-packages/pybombs/recipes’ for recipes…
PyBOMBS.RecipeListManager - DEBUG - Found 11 new recipes.
PyBOMBS.install - DEBUG - Initializing command class for command install
PyBOMBS.PackageManager - DEBUG - No prefix specified. Skipping source package manager.
PyBOMBS.PackageManager - DEBUG - Attempting to add binary package manager pip
PyBOMBS.PackageManager - DEBUG - pip is supported!
PyBOMBS.PackageManager - DEBUG - Attempting to add binary package manager apt
PyBOMBS.PackageManager - DEBUG - apt is supported!
PyBOMBS.PackageManager - DEBUG - Attempting to add binary package manager yumdnf
PyBOMBS.PackageManager - DEBUG - Attempting to add binary package manager port
PyBOMBS.PackageManager - DEBUG - Attempting to add binary package manager brew
PyBOMBS.PackageManager - DEBUG - Attempting to add binary package manager zypper
PyBOMBS.PackageManager - DEBUG - Attempting to add binary package manager pacman
PyBOMBS.PackageManager - DEBUG - Attempting to add binary package manager portage
PyBOMBS.PackageManager - DEBUG - Attempting to add binary package manager pymod
PyBOMBS.PackageManager - DEBUG - pymod is supported!
PyBOMBS.PackageManager - DEBUG - Attempting to add binary package manager pkgconfig
PyBOMBS.PackageManager - DEBUG - pkgconfig is supported!
PyBOMBS.PackageManager - DEBUG - Attempting to add binary package manager cmd
PyBOMBS.PackageManager - DEBUG - cmd is supported!
PyBOMBS.PackageManager - DEBUG - Using binary packagers: [‘pip’, ‘apt’, ‘pymod’, ‘pkgconfig’, ‘cmd’]
PyBOMBS.install_manager - OBNOXIOUS - Checking if package `soapysdr’ goes into tree…
PyBOMBS.PackageManager - DEBUG - Checking if package soapysdr is installable…
PyBOMBS.Recipe[soapysdr] - OBNOXIOUS - Loading recipe file: /home/jason/.pybombs/recipes/gr-recipes/soapysdr.lwr
PyBOMBS.Recipe[soapysdr] - OBNOXIOUS - Loading template file: /usr/local/lib/python2.7/dist-packages/pybombs/templates/cmake.lwt
PyBOMBS.Recipe[soapysdr] - OBNOXIOUS - Inheriting from file /usr/local/lib/python2.7/dist-packages/pybombs/templates/cmake.lwt
PyBOMBS.Recipe[soapysdr] - OBNOXIOUS - Loading template file: /usr/local/lib/python2.7/dist-packages/pybombs/templates/empty.lwt
PyBOMBS.Recipe[soapysdr] - OBNOXIOUS - Inheriting from file /usr/local/lib/python2.7/dist-packages/pybombs/templates/empty.lwt
PyBOMBS.Recipe[soapysdr] - OBNOXIOUS - Loaded recipe - soapysdr
PyBOMBS.get_recipe - OBNOXIOUS - Woohoo, this one’s already cached (soapysdr)
PyBOMBS.Packager.pip - OBNOXIOUS - exists(soapysdr)
PyBOMBS.ReqScanner - OBNOXIOUS - Empty requirements string.
PyBOMBS.Packager.apt - OBNOXIOUS - exists(soapysdr)
PyBOMBS.Packager.pymod - OBNOXIOUS - exists(soapysdr)
PyBOMBS.Packager.pkgconfig - OBNOXIOUS - exists(soapysdr)
PyBOMBS.Packager.cmd - OBNOXIOUS - exists(soapysdr)
PyBOMBS.PackageManager - DEBUG - Package soapysdr is not installable.
PyBOMBS - DEBUG - Unresolved install path.
