@adim - Adrian
I have all the dependencies installed and compiled the app fine this evening. However, I was unable to start the LimeSDR USB or the Lime Mini I have even when I set the receive and transmit settings in the ‘Setup’ tab like you’d expect for GNURadio (driver=lime, soapy=0). Woudn’t start the Lime at all (both of my Limes have the updated firmware to the currrent revision). So I fell back A LOT and installed an RTL-SDR and set the receive path in the ‘Setup’ to: rtl=0. Restarted the app and I was able to tune and listen to the FM radio band fine and some of the weather stations (162.475 MHz WXL71 in Cedar Rapids, Iowa). So the app works, it just isn’t working (or recognizing) the Lime(s).
Can you let me know the following setup syntax for receive and transmit for the following:
LimeSDR USB
Lime Mini
Red Pitaya
HackRF
I would like to see if I can get any (or all) of those working with the app. I don’t know what setup syntax for receive and transmit will be for all those SDRs that I have for testing.
Also, for the Red Pitaya, is there anything I need to do with the Ethernet setup to make it work? Please let me know on that, too.
I have my Linux Box and a Linux Laptop setup on your app and both work with a RTL-SDR.
Please advise at your soonest - thanks,
