hi There
hope I am writing to the right forum…
I am running windows 7, 64bit on a high end dell machine.
in windows device manager, I see my LIMESDR, I tried to download the driver per the instruction, from cypress, and do an update. Am I missing something?, After installing the huge cypress file, it is not clear what to do!.
when I try to update the driver, windows 7 keep telling me- my driver is the proper one, and I do see the board.
the FPGA1 LED blinks RED-Green, the board seems to run Hot to the touch? is that normal?
and the second LED to the right of the FPGA1 LED is totally off I see 2 labels next to it, FPGA2 and LEDS1)
I can NOT communicate with the board.
I did see the history at the link below
I have a copy of the board that Fox_Mulder showed in the link above on Feb 17!!! and appear to have
a similar problem to his, if I can not communicate with the board, how can I upgrade the firmware?
is it possible that I have a faulty board?
if I need to exchange it, please let me know.
none of the command line {commands} I issue can see the board, of course the LMSUITE can not see it either.
Zadig 's pulldown can see the board!
------------------------------------------------------------------here are the commands I issued after review of postings <<<
C:\Program Files\PothosSDR\bin>soapysdrutil --info -------------------------------------<<<<
Lib Version: v0.6.1-PothosSDR-2018.01.11-vc14-x64
API Version: v0.6.0
ABI Version: v0.6
Install root: C:\Program Files\PothosSDR
Search path: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/airspySupport.d
ll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/audioSupport.dl
l
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/bladeRFSupport.
dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/HackRFSupport.d
ll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/IrisSupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/LMS7Support.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/miriSupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/osmosdrSupport.
dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/RedPitaya.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/remoteSupport.d
ll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/rtlsdrSupport.d
ll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/sdrPlaySupport.
dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.6/uhdSupport.dll
Loading modules… Win32; Microsoft Visual C++ version 14.0; Boost_106300; UHD_0
03.010.003.000-0-gd9643b9d
done
Available factories…airspy, audio, bladerf, hackrf, iris, lime, miri, null, os
mosdr, redpitaya, remote, rtlsdr, sdrplay, uhd,
C:\Program Files\PothosSDR\bin>Fox_MulderFox_MulderFox_MulderFox_Mulder
‘Fox_MulderFox_MulderFox_MulderFox_Mulder’ is not recognized as an internal or e
xternal command,
operable program or batch file.
C:\Program Files\PothosSDR\bin>limeutil --info -----------------------------------------------<<<<<<
LimeSuite information summary
Version information:
Library version: v18.01.0-PothosSDR-2018.01.11-vc14-x64
Build timestamp: 2018-01-11
Interface version: v2017.12.0
Binary interface: 18.01-1
System resources:
Installation root: C:\Program Files\PothosSDR
User home directory:
App data directory: C:\Users\uidq9714\AppData\Roaming/LimeSuite
Config directory: /.limesuite
Image search paths:
- C:\Users\uidq9714\AppData\Roaming/LimeSuite/images
- C:\Program Files\PothosSDR/share/LimeSuite/images
Supported connections:
- PCIEXillybus
- STREAM
- uLimeSDR
C:\Program Files\PothosSDR\bin>soapysdrutil --find=“driver=lime” -------------------------<<<
Win32; Microsoft Visual C++ version 14.0; Boost_106300; UHD_003.010.003.000-0-gd
9643b9d
No devices found!
thanks
roger
